brake lights failing
2003 BMW 530I
127,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
BARRY MOSS
I bought the car online and got it yesterday. I looked the car over and found that one brake was on but nothing else, no turning signals or back up lights in the rear. In the front no turn signals. I check the bulbs and none blown. Any idea what to look for? this is my first BMW.
Aug 28, 2017 at 9:33 AM
CARADIODOC
  • 34,381 POSTS
Do you mean that brake light is on all the time, or that is the only light that works when it is supposed to?
With so many dead circuits, the best suspect is the light control module. It is behind the right kick panel. Normally I would have you check for twelve volts and ground on that module before replacing it, but there is no reference to those circuits on the diagrams, so I cannot tell which wires those are.
Aug 28, 2017 at 3:17 PM
BARRY MOSS
When I press the brake pedal the only light that comes on is right rear checked all bulbs and none blown.
Aug 29, 2017 at 12:46 AM
CARADIODOC
  • 34,381 POSTS
Okay. Logic tells me the light control module must be getting twelve volts and ground if any circuit works. That leaves the module as the best suspect.
Aug 29, 2017 at 12:16 PM
