Brake lights, and dash lights not working
300,000 MILES • 5.9L • 6 CYL • TURBO • 4WD • AUTOMATIC
SCOTT'S
My tuck has a Cummings turbo diesel engine in it. It is my first diesel, so a lot of it is foreign to me. But, electrical is electrical, and I cannot seem to find a root problem. I have no rear brake lights, but the one on the cab works. And I have no dash lights. The brake light fuse tests hot on both sides all the time. Are the two systems connected?
Aug 23, 2016 at 11:20 PM
WRENCHTECH
  • 20,760 POSTS
You have to approach these problems separately and the path of diagnostics will tell you if they are connected or not. I doubt they are. The lower two brake lights run through the turn signal switch so the turn signals can cancel the brake lights. https://www.2carpros.com/images/external/62564886.gif
Aug 23, 2016 at 11:30 PM
