Brake light on back windshield does work. Bulbs and fuses are good. Could it be the brake switch?
Oct 19, 2019 at 1:38 AM
✓Experienced Mechanic
It could be yes there are two wire feeds through the switch. here is a guide to help you test the switch and the wiring diagrams below so you can see how the system works:
