Brake lights will not turn off
150,000 MILES • 2WD • MANUAL
BWINN
My brake lights will not turn off. I only use this truck to haul dirt and lumber, mostly on my property. Not able to get it repaired right now. Can I just remove the fuse labeled "stop lights" when I turn the truck off and put the fuse back in if I have to drive on a public road.
Jan 21, 2018 at 7:03 AM
CJ MEDEVAC
  • 11,000 POSTS
Below (at bottom), I found what should be a picture of your brake light switch.
It could be a defective switch
or
It may just have a "mounting" problem.
My Jeep's switch is similar to yours.
I am linking you to a post where I explain what could be wrong. See my answer's in this link.
https://www.2carpros.com/questions/1979-ford-f-100-brake-light-switch
Return here (this thread) and let us know what you found.
The Medic
Jan 21, 2018 at 9:46 AM
