My brake lights stopped working. Bulbs are good. What do I need to look at next? Thanks.
Nov 22, 2016 at 3:45 PM
✓Experienced Mechanic
Check brake light fuse and check that there is power at the brake light switch and that the power passes through the switch when activated. the switch is located under the dash at the top of the brake pedal.
