Brake lights stay on all the time
300,000 MILES
JRAY1979
Also, the cruise control stopped working. I replaced the brake switch and it didn't help.
Feb 13, 2022 at 3:28 AM
WENDY W
  • 86 POSTS
Hello!
It sounds like there could be a fault in the turn signal multifunction switch which could be passing voltage through from the brake light switch to the stop lamps, even without the brake pedal being pressed. This could also interfere with cruise control operations. I've attached the stop lamp schematic for your reference.
This multifunction switch is located in the steering column and is labeled #23 in the component diagram. Please check out the diagrams (below).
Please note, the SIR system (supplemental inflatable restraint) holds a reserved energy supply for several minutes after disconnecting power to the vehicle. Please use caution when testing or servicing components near any part of the airbag system.
You may find the following repair guides and video helpful:
https://youtu.be/Hlna_kUt7As
Please let us know what you find.
Thanks, Wendy W
Feb 13, 2022 at 10:14 PM
JRAY1979
Thank you for your reply. It wasn't that, but I was finally able to track it to a faulty trailer brake box. Thank you for your reply and your help.
Feb 15, 2022 at 8:50 AM
WENDY W
  • 86 POSTS
Thank you for the update! I'm glad you were able to track down the issue.
Please don't hesitate to let us know if there's anything else we can assist you with in the future.
Thanks! Wendy W
Feb 15, 2022 at 9:42 PM
