Brake lights.
156,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JRCDADDY
Brake lights don't work. Fuse is good. Is the next step replace brake pedal switch?
Aug 26, 2016 at 10:01 PM
HMAC300
  • 48,601 POSTS
see if you have poser going in and out of it. a test light or volt meter works best. then check the same on t/s switch. if those are good it may be the hazard module which may need a scanning by a mechanic to verify
Aug 26, 2016 at 11:01 PM
