brake lights
180,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
BADBOYSLIM79
No bottom back brake lights, no turn signals or flashers. Replaced multifunction switch and brake pedal switch, check all fuses and they are good also replaced bulbs. Don't know what else to do.
Apr 5, 2016 at 9:50 AM
HMAC300
  • 48,601 POSTS
check to see if power is coming from multi function switch in pic then if coming to lights. if goes out switch and not to lights then it's a broken wire if not going into switch which is re/lt grn then it may be a problem there . finally check ground wire connection right rear of trunk.
Apr 6, 2016 at 2:58 AM
HMAC300
  • 48,601 POSTS
also check electronic flasher module in central junction box.
Apr 6, 2016 at 2:59 AM
