Brake lights not working?
187,000 MILES • 3.4L • AUTOMATIC
ERICK57
There are 4 bulbs that are my lower brake lights. 3 of them don't work. One does. The upper light also works. All taillights and turn signals work. The fuses look good, and I've switched out bulbs, but there's no change.
Sep 3, 2023 at 5:10 AM
  • 110,248 POSTS
I'm looking at the wiring schematics and it only shows two rear brake lights and one center high-mount brake light. Where are you seeing two?
The brake lamp bulb is a dual-element bulb. One element is a parking lamp and the other is for the brakes.
Let me know. I attached the wiring schematic below, so you have a reference. I highlighted the relevant controls.
joe
See pics below. Note: I had to cut each of the two pages in half to make them readable. I did overlap them so you can follow from one to the next.
Sep 3, 2023 at 3:36 PM
