Brake light will not turn off
165,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
KERWIN CAPERS
Brake light stays on when driving and when the car is off. I changed the brake switch after checking on the web for some results. but that did not fix the problem. I also tried changing the fuse inside the car fuse box with another fuse the same size that did not work either. I hear there might be a relay switch but have no clue where to find it. I checked the fuse boxes in the engine did not see one mark for the brake light. any suggestions on how to fix? When I press the brake switch the light gets brighter, instead of going off.
Dec 12, 2017 at 4:39 AM
CJ MEDEVAC
  • 11,000 POSTS
I looked up your switch at Autozone (online)
Works very similar to my '77 Jeep CJ-5
The switch's plunger should be "IN" when the pedal is released (up).
You may have to slide/ adjust/ lock down the body of the switch in it's holder to make this happen against the "stop" (unable to grab a better word!).
I'm sending you a link to another answer I gave to someone else (See "my answers" in the link) I made a few pics in there too.
https://www.2carpros.com/questions/1979-ford-f-100-brake-light-switch
Keep us posted on progress.
Maybe it's just that simple!
The Medic
Dec 12, 2017 at 9:38 AM
