Brake light wire
199,000 MILES • 3.6L • V8 • 2WD • AUTOMATIC
JAY RIMES JR.
My brake lights stopped working so I reached my hand underneath and found at a connection that if I move the wires a little they worked again. About two months later they stopped working again and I wiggled the same spot and they worked again. They just stopped again and I wiggled the wires and it was working but went out a few miles down the road again and will not come on anymore. I moved them around and nothing.
Sep 6, 2018 at 10:34 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Check if you blew fuse #6 in the smart junction box at the right kick panel. Also, check fuse #46 in the battery junction box, located near the battery under the hood. Then when they come back on you should fix that connection.
Sep 7, 2018 at 2:13 AM
