brake light switch
150,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
MMSUPFDF
when pedal is depressed brake lights do not come on, but if you lift up or put a small piece of cardboard under the brake light switch they com on when pedal is depressed. is this an idication of a faulty switch?
Feb 11, 2016 at 6:35 AM
CJ MEDEVAC
  • 11,000 POSTS
I HAVE TWO POSSIBILITIES FOR YOU
1) THE SWITCH HAS BEEN PUSHED REARWARD IN IT'S HOLDER
THIS LINK MIGHT EXPLAIN IT MORE (SEE MY ANSWERS)
www.2carpros.com/questions/1979-ford-f-100-brake-light-switch
2) A PIECE OR PART, PROBABLY PLASTIC OR RUBBER HAS FALLEN OFF OF THE BRAKE PEDAL FLAT SPOT (NOW IT DON'T REACH-LIKE YOUR CARDBOARD DOES NOW)
THIS LINK IS A SIMILAR SITUATION, IT HAD A RUBBER DISC ON THE PEDAL PART
www.2carpros.com/questions/1984-nissan-300zx-brake-and-light-problem
LEMME KNOW WHAT YOU FIND
THE MEDIC
Feb 11, 2016 at 7:28 AM
JOHNNYT73
  • 924 POSTS
No, there is usually a grommet in the hole of the arm of the break pedal. Its where the switch contacts the arm. The grommet can fall/fail and need replacing. Im trying to understand what you are saying exactly of the position of the cardboard your using. If the grommet is there then you can sometime adjust the switch by adjusting the nuts on it to make better contact. Be careful not to adjust too much because it will keep your brake applied.
Feb 11, 2016 at 7:30 AM
MMSUPFDF
the cardboard is under the switch and lifts up the back of the switch slightly. If I lift it up too much the brake lights stay on
Feb 11, 2016 at 7:35 AM
JOHNNYT73
  • 924 POSTS
Check to see if it can be tightened. If it looks wore and pushed back then it may need replacing.
Feb 11, 2016 at 7:36 AM
