Brake light switch
1994 DODGE DAKOTA
90,000 MILES • 3.8L • V8 • 2WD • AUTOMATIC
HELPPPPPPP
I simply hope that somebody can tell me how to check the switch/short wiring harness with my ohmmeter. in other words, I do not know what wires to put my test leads on so that when I push the "switch button" I will be able to see if the switch actually is working. ; )
Thanks.
Dec 7, 2017 at 8:13 AM
CARADIODOC
  • 34,384 POSTS
What kind of problem are you trying to solve? What is the correct engine size, and do you have cruise control? I assume you know how to use an ohm meter and voltmeter. Is that correct?
Dec 7, 2017 at 8:35 AM
