The brake light is stuck in the on position?
2006 PONTIAC G6
175,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
JAMESB2019
  • 42 POSTS
I need to take the brake light switch and its white bracket out and test them or replace them. Will that affect the actual braking?
Aug 29, 2022 at 9:19 AM
  • 110,244 POSTS
If you remove the brake light switch, it will not affect the actual braking, but you will have no brake lights. If it is sticking on, reach up under the dash and see if it is loose or stuck.
If you need to remove it, here is a link you may find helpful:
https://www.2carpros.com/articles/how-to-replace-a-brake-light-switch
Let me know what you find or if I can help in any way.
Aug 29, 2022 at 12:56 PM
JAMESB2019
  • 42 POSTS
Great, thank you.
Aug 29, 2022 at 2:09 PM
  • 110,244 POSTS
No problem whatsoever. Let me know what I can do to help.
Aug 30, 2022 at 11:44 AM
