Brake light on
110,000 MILES
MELISSA_FISCHER1979
My brake light came on brakes are acting fine. My son's father took it to a mechanic he said its a bad solenoid. What does that mean? Is it something i have to take care of ASAP and is it expensive? Thanks
Mar 19, 2019 at 6:14 AM
  • 110,248 POSTS
Can you tell me if the brake light is red or yellow? Also, is the ABS light on? Also, do you mean a wheel speed sensor is bad and not a solenoid? If you have the estimate sheet from the shop, tell me exactly what it says.
Here are a couple links you may find helpful:
https://www.2carpros.com/articles/brake-system-warning-light-on
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/abs-brake-system-repair
Mar 19, 2019 at 11:09 AM
