Brake light fuse
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIM KARG
Where is the fuse for the brake lights located? nothing is listed on the list of fuses about brake lights.
Nov 4, 2017 at 12:08 AM
  • 55,781 POSTS
The problem is probably with the turn signal flasher module which control everything for the brake lights.
Here is a wiring diagrams and a guide so you can do a test to confirm:
Here is the location of the flasher as well and you should check all of the fuses:
Cheers, Ken
Nov 5, 2017 at 10:18 AM
