Diagram was not for brake lights, have put bulb in from left side. Where does the 12 volts split for left and right? (Ignition switch?)
Jul 23, 2018 at 5:05 AM
✓Experienced Mechanic
It spits at the turn signal switch which sounds like it is bad. Here is a guide and the blinker wiring so you can confirm the power loss at the switch:
