Driver's side brake light not working
165,000 MILES • 6 CYL • 2WD
JANET PARKE
Driver side brake light will not work when I apply the brake pedal .all other lights work. Changed the socket because it was corroded and of course the bulb. But it still won't work . Can you help?
Nov 28, 2020 at 6:45 AM
  • 110,246 POSTS
If the other brake light is working and the lights on the left side (other than the brake light)are working, then we know it isn't a switch or a ground issue.
I attached a pic below showing a portion of the wiring schematic. I circled two things in the pic. First, I want you to check if there is power to the green wire at the light when the brake is applied.
If there isn't, then the next concern is the splice I circled. Chances are the connection has failed. If you look at pic 2, it explains where the joint connector is located. I will need you to check there next.
Do this and let me know what you find.
Nov 28, 2020 at 1:59 PM
JANET PARKE
The problem has been fixed. thank you all. it was the socket where the bulb went in, it was burnt on the inside.
Apr 20, 2021 at 2:24 AM
  • 55,583 POSTS
JACOBANDNICKOLAS is one of best! Good to hear, please use 2CarPros anytime we are here to help.
