replaced the master cylinder and braking has improved, but still goes to floor when held
2009 LINCOLN
100,000 MILES • 3.7L • V6 • FWD • AUTOMATIC
THOTRODDER
MEMBER
Brake pedal goes to the floor. I replaced the master cylinder and braking has improved, but still goes to floor when held.
Nov 19, 2016 at 7:13 AM
✓Experienced Mechanic
Did you re-bleed the entire brake system after replacing the master cylinder?
Nov 19, 2016 at 4:38 PM
THOTRODDER
MEMBER
Yes.
Nov 19, 2016 at 8:58 PM
if you pump the pedal and hold it will it stay up? does it fall away under light pedal application?
Nov 20, 2016 at 4:32 AM
THOTRODDER
MEMBER
It will start to fade to the floor.
Nov 20, 2016 at 11:41 AM
It sounds like there is air trapped in the ABS unit and you must have a scanner to open each valve to bleed it, this does happen all the time but it does happen.
Please let us know happens so it will help others.
