After replacing the brakes and bleeding the system the brake pedal still goes down?
GOGOJUICE6
  • 1994 FORD RANGER
  • 2.3L
  • 4 CYL
  • MANUAL
  • 113,000 MILES
I just replaced mc (bled it)wheel cylinders, rear brake lines, including center flex hose, shoes, flushed and bled system and brake pedal still goes down, almost to the floor. What am I doing wrong?
Thanks for your help.
Monday, December 16th, 2024 AT 8:51 AM
MECHTRIX
  • 54 POSTS
Might be time to replace the master cylinder.
Monday, December 16th, 2024 AT 5:05 PM
MECHTRIX
  • 54 POSTS
Or the brake booster . Check those first. Hope this helps good luck
Monday, December 16th, 2024 AT 5:07 PM
GOGOJUICE6
  • 75 POSTS
Master cylinder is brand new.
Tuesday, December 17th, 2024 AT 2:10 AM
