Brake pedal goes to the floor
180,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
LORIED12
  • 9 POSTS
Replaced front pads, rotors, calipers, ABS pump and master cylinder. I bled everything; brake pedal goes to the floor but when I pump the pedal the brakes work. Where should I look next?
Apr 19, 2022 at 10:55 AM
  • 110,248 POSTS
First, was this the issue prior to replacing the components? Also, I want you to do something. Turn the key off and pump the brake pedal to make it solid. Hold a steady amount of pressure on it and see if it slowly goes to the floor.
Also, I attached the bleed procedure from my manual. Take a look through it and let me know if there is anything you may have missed.
Apr 19, 2022 at 1:46 PM
LORIED12
  • 9 POSTS
The original issue was brake pads. The brake pedal stays when you apply pressure with the key off.
Apr 19, 2022 at 10:12 PM
  • 110,248 POSTS
Okay, then it's unlikely there is a problem with the new MC. I suspect you still have air in the system. When you start the vehicle, you get the power assist which allows the pedal to reach the floor.
Did you bench bleed the new MC? Also, when bleeding, did you follow the directions listed above?
Apr 20, 2022 at 12:15 PM
LORIED12
  • 9 POSTS
Yes, I followed the instructions on the bench bleeding the master cylinder. The only other thing I haven’t done is bleed the brakes while cycling the ABS pump. I also bled the brakes according to the instructions you posted twice before I asked any questions about what else could be wrong.
Apr 20, 2022 at 1:08 PM
  • 110,248 POSTS
I suspect that is where there is air in the system, the ABS.
I attached the directions for bleeding the ABS. It requires a scan tool that can communicate with the ABS module.
Take a look through them and let me know if it is something you can have done or get the scan tool to do yourself.
Apr 20, 2022 at 2:09 PM
LORIED12
  • 9 POSTS
My son has a scan tool we’re going to do it this weekend.
Apr 21, 2022 at 12:24 AM
  • 110,248 POSTS
Excellent! Let me know if that takes care of the problem.
Apr 21, 2022 at 9:04 AM
LORIED12
  • 9 POSTS
We bled the ABS pump and that didn’t change anything. At this point the only other thing is I’m wondering if I bought a master cylinder that is bad. After I replaced the Master Cylinder, I have a brake light on the dash that I didn’t have before. I’m going to return the one I installed and get another one to see if this is the issue.
Apr 23, 2022 at 11:35 PM
  • 110,248 POSTS
If there are no leaks and everything is bled, the only other thing I can think of is if the pushrod between the MC and the booster is out of adjustment.
I attached directions for adjustment below. Check this before returning the Master Cylinder.
Let me know what you find.
See pic below.
Apr 24, 2022 at 11:37 AM
LORIED12
  • 9 POSTS
I checked the length of the push rod, and it is good. I then replaced the master cylinder. The brake light also went away. I also found the vacuum line to the power booster had a hole in it and replaced that. I need to bleed the brakes again, but the pedal still seems to go right to the floor when I first step on it. When I pump the pedal a few times it comes up and works close to normal. If bleeding the brakes doesn’t solve the issue, I’m not sure what to do next.
Apr 29, 2022 at 9:20 PM
  • 110,248 POSTS
Thanks for the update. When you bleed it, make sure to also perform the automated bleed.
Also, and don't laugh, make sure the rubber brake hoses at the calipers aren't expanding when you apply the brakes. I've seen it happen twice in my life, but it can happen.
See pic below.
Apr 30, 2022 at 12:28 PM
LORIED12
  • 9 POSTS
I have now bled the brakes and there is no air to be found. The pedal still goes to the floor. All the lines look good. So, at this point is it possible the power booster is bad?
May 2, 2022 at 11:52 AM
  • 110,248 POSTS
The brake booster simply makes pressing the brakes easier. Anything is possible, but that doesn't make sense to me. Hydraulics can only travel so far.
Are you able to pump the brakes up with the engine running or off, and get a good solid pedal?
May 3, 2022 at 8:38 AM
LORIED12
  • 9 POSTS
It’s still a little spongy I was talking with some who asked me if I was sure I had the calipers on the correct side after checking I think I switched them. I have the bleeders facing down and from the pictures they should be facing up.
May 3, 2022 at 8:54 AM
  • 110,248 POSTS
Absolutely that is the problem. You can't get rid of the air if the bleeder is pointing downward. It sounds like you found the problem. I know it can happen but never thought to mention it because you had done so much work, I assumed they were correct. Well, that is what happens when one assumes.
Let me know if that takes care of the problem. I am very confident it will.
May 3, 2022 at 10:29 AM
LORIED12
  • 9 POSTS
Yes, it took care of it. When I started this whole deal, I was trying to go too fast and fighting to get the parts before the stores closed. Thanks for the help.
May 3, 2022 at 1:13 PM
  • 110,248 POSTS
I appreciate the update. Also, it's good to hear the problem is resolved.
Please feel free to come back anytime in the future. You are always welcome here.
May 4, 2022 at 7:35 AM
