I think the brake will work better
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
BAYDREW275
After this work is done I think the brake will work better
Jul 8, 2016 at 11:28 AM
  • 110,246 POSTS
Replacing rear brake pads and rotors really isn't that difficult. When you do it yourself, make sure to get lifetime replacement parts so you never have to pay again.
You can expect rear brakes to last approximately 30,000, but that will vary based on terrain and driving habits.
First, here is a link that shows in general how it's done. You can use this as a guide.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
this will show ho to retract the caliper
https://youtu.be/j8YwfSKEzZo
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
____________________________________________
2010 Ford Mustang V6-4.0L
Brake Pads
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Removal and Replacement Rear Disc Brake Brake Pads
BRAKE PADS
Brake Pads
pic 1
pic 2
Removal
WARNING: Do not use any fluid other than clean brake fluid meeting manufacturer's specification. Additionally, do not use brake fluid that has been previously drained. Following these instructions will help prevent system contamination, brake component damage and the risk of serious personal injury.
WARNING: Carefully read cautionary information on product label. For EMERGENCY MEDICAL INFORMATION seek medical advice. In the USA or Canada on Ford/Motorcraft products call: 1-800-959-3673. For additional information, consult the product Material Safety Data Sheet (MSDS) if available. Failure to follow these instructions may result in serious personal injury.
WARNING: Always install new brake shoes or pads at both ends of an axle to reduce the possibility of brakes pulling vehicle to one side. Failure to follow this instruction may result in uneven braking and serious personal injury.
NOTICE: Do not spill brake fluid on painted or plastic surfaces or damage to the surface may occur. If brake fluid is spilled onto a painted or plastic surface, immediately wash the surface with water.
1. Remove the wheel and tire. For additional information, refer to Wheels and Tires.
2. NOTICE: Care must be used when servicing rear brake components without disconnecting the parking brake cable from the brake caliper lever. Carefully position the caliper aside using a suitable support or damage to the parking brake cable end fittings may occur.
NOTICE: Do not use caliper sight hole to retract pistons as this may damage the pistons and boots.
NOTICE: Do not allow the caliper to hang from the brake hose or damage to the hose may occur.
Remove the 2 brake caliper guide pin bolts and position the brake caliper aside.
- Support the caliper using mechanic's wire.
3. Remove the brake pads and discard the spring clips.
4. Measure the brake disc thickness.
- Install a new brake disc if not within specification. For additional information, refer to Brake Disc See: Brake Rotor/Disc > Removal and Replacement > Brake Disc.
5. Inspect the brake caliper.
- If leaks or damaged boots are found, install a new brake caliper. For additional information, refer to Brake Caliper See: Brake Caliper > Removal and Replacement > Brake Caliper.
6. Inspect the brake caliper anchor plate assembly.
- Check the guide pins and boots for binding and damage.
- Replace worn or damaged pins. Lubricate the pins with the specified grease.
- Install a new brake caliper anchor plate if it is worn or damaged.
Installation
1. Using the Rear Brake Caliper Piston Adjuster Adapter, compress the brake caliper piston into the brake caliper bore.
pic 3
2. Position the notch in the caliper piston up and down to align with the alignment pin on the brake pad.
3. NOTICE: Do not allow grease, oil, brake fluid or other contaminants to contact the pad lining material, or damage to components may occur. Do not install contaminated pads.
NOTE: Install all hardware supplied with the pad kit.
Install the 2 new spring clips and the brake pads.
pic 4
4. Position the brake caliper on the anchor plate and install the 2 brake caliper guide pin bolts until snug.
- Tighten the RH caliper guide pin bolts in the following sequence:
- Tighten the top bolt to 33 Nm (24 lb-ft).
- Tighten the bottom bolt to 33 Nm (24 lb-ft).
- Tighten the LH caliper guide pin bolts in the following sequence:
5. Install the wheel and tire. For additional information, refer to Wheels and Tires.
- Apply brakes several times to verify correct brake operation.
Rotor Replacement
Brake Disc
Vehicle Brakes and Traction Control Disc Brake System Brake Rotor/Disc Service and Repair Removal and Replacement Rear Disc Brake Brake Disc
BRAKE DISC
Brake Disc
pic 5
Removal
NOTICE: Do not allow the brake caliper and anchor plate assembly to hang from the brake hose or damage to the hose may occur.
Remove and discard the 2 anchor plate bolts and position the brake caliper anchor plate and brake caliper assembly aside.
3. Remove the brake disc.
Installation
1. Clean any rust or foreign material from the brake disc and the wheel hub.
- Use the specified brake parts cleaner to clean the brake disc and hub surfaces.
2. NOTICE: In order for the brake caliper anchor plate bolts to attain the proper clamp load when installed, the residual threadlock compound must be cleaned out of the bolt threads of the anchor plate.
Clean any residual threadlock compound, and any other foreign material, from the threads of the brake caliper anchor plate.
3. NOTICE: Do not allow the lubricant to make contact with the wheel studs, brake pads or brake disc or damage to components may occur.
Apply a thin coat of the specified anti-seize lubricant to the hub flange.
4. Position the brake disc onto the wheel hub.
5. Position the brake caliper anchor plate and install 2 new anchor plate bolts.
- Tighten to 103 Nm (76 lb-ft).
6. Install the wheel and tire. For additional information, refer to Wheels and Tires.
I hope this helps. Let me know if you have other questions.,
Take care and God Bless,
Mar 2, 2021 at 6:19 AM
