Brake pedal is soft
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
BAYDREW275
Replace front and rear brake pads and rotors, Replaced master cylinder, Replaced brake booster, Replaced four caliper flex hoses, Bled brake system?
Jul 8, 2016 at 11:25 AM
CJ MEDEVAC
  • 11,000 POSTS
I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Jul 8, 2016 at 11:34 AM
JOHNNY G.JR
  • 320 POSTS
A power bleeding might be in order,after bench procedure,possible sequence out of order Rrear,Lrear,Rfront,Lfront
Jul 8, 2016 at 2:48 PM
