Brake fuse keeps blowing after applying brakes
227,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SALVADOR7780
#25 brake fuse keeps blowing after pushing brakes. They light on for a split second then off. Fuse is blown. Took taillight off, wires look good. Does have trailer lights hook up.
Oct 16, 2019 at 10:53 AM
SCGRANTURISMO
  • 4,897 POSTS
The fuse for the brake lights keeps blowing because you have a short to ground somewhere in the circuit that the fuse is protecting. In the diagrams down below I have included the wiring diagram for the brake circuit which includes fuse 25 and a guide on how to track down a short to ground in an automotive electrical circuit. You will need to use a Digital Multi-meter [DMM] to do this so I have also included a link to a guide on how to use one, if you are unfamiliar with the tool down below:
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2carPros
Oct 16, 2019 at 11:33 AM
SALVADOR7780
Thank you Granturismo. I'll work on it this weekend. Great information.
Oct 17, 2019 at 3:43 AM
