My car is a 1998 Chevrolet Lumina. there was AutoLock light on the dash. I replaced Fuse 16 and fixed the problem. But after I foot on brake pad strongly three times before start engine there was Brake light on the dash board, and the brake does not apply efficiently, brake only slightly work. And that time brake fluid level in muster cylinder was full, but after one day the level is go to bottom surface of tank. After I fill full but once again it gone to bottom.
I found thin brake line rusted line attached to body where was leaking at rear left tire. Is it possible replace the brake pipe line by myself? How
How much cost for the repair?
Thanks!
Steven
Thanks!
Steven
Jan 23, 2014 at 2:47 AM
