Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Sienna
Brakes
Brake Fluid
Leak
Brake fluid leak
2006 TOYOTA SIENNA
183,000 MILES • V6
LUNCHMEAT
MEMBER
1 POST
Changed the master cylinder, back brakes and rotors. Now all the brake fluid leaks out and brake pedal goes to the floor.
Feb 24, 2018 at 8:52 PM
Experienced Mechanic
Good morning.
Did you inspect all the lines for leaking? If the fluid is gone there is a leak somewhere. Inspect all the lines and hoses for any leaks.
Feb 24, 2018 at 11:26 PM
PATENTED_REPAIR_PRO
Where is the leak?
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Check engine light
Engine won't start
