Brake fluid added to the coolant reservoir
40,000 MILES • 3.8L • 6 CYL • 2WD • MANUAL
GSOUSA
About 500 miles ago I inadvertently added 1 liter of brake fluid into the coolant reservoir (32 litre capacity). I am going to flush, but can I expect any damage as a result of my mistake?
Thanks,
Gary
May 24, 2021 at 7:14 AM
Here is a guide that will help with this in case you need it:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
To answer your question on this, it is unlikely that it did major damage. The main thing you would need to worry about is the heater core plugging.
What I would do is flush the cooling system like you are planning and then use a laser temp meter to check the temperature on both lines coming from and going to the heater core. They should be about the same.
https://www.2carpros.com/articles/how-to-use-an-infrared-temperature-meter
If that is okay then I would not worry too much about it as it is not uncommon to have oil and other contamination in the cooling system. It is pretty resilient, even though brake fluid is more corrosive.
Let us know if you have other questions. Thanks
May 25, 2021 at 1:19 PM
