Losing brake fluid, but there is no sign of a leak anywhere
1999 FORD TAURUS
160,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
MICHAEL CARPENTER
It was raining, I hit my brakes wild stop then bad pedal. Hardly any brakes. No brake fluid in master cylinder.
Aug 16, 2018 at 4:25 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Hmm, Since brakes are a sealed system the fluid has to be going somewhere. If you are not noticing on the ground maybe the master cylinder is leaking into the power brake booster. You might want to add more fluid a monitor if it is leaking down still. Definitely need to be looked at because no brakes would be dangerous. I am attaching a few links to explain symptoms and how to change a master cylinder. Hope this helps and feel free to answer any other questions if needed. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Aug 16, 2018 at 11:11 AM
