Can I use dot 3 brake fluid in my vehicle?
67,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
AUSTINO
  • 231 POSTS
Brake Fluid.
Oct 9, 2023 at 10:42 AM
  • 110,251 POSTS
It is recommended to only use the manufacturer's DOT 4 brake fluid. DOT 4 brake fluid is backward compatible with DOT 3 systems. This means you can use DOT 4 in a vehicle that originally used DOT 3 fluid. However, the reverse is not recommended. You should not use DOT 3 fluid in a system designed for DOT 4.
Let me know if that helps.
Oct 9, 2023 at 12:49 PM
AUSTINO
  • 231 POSTS
Oct 28, 2023 at 6:37 AM
  • 110,251 POSTS
You are very welcome. Feel free to come back anytime in the future.
Take care of yourself,
Oct 28, 2023 at 1:44 PM
