Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Aura
Brakes
ABS
Wheel Speed Sensor
Replace/Remove
later the right front brake wheel speed sensor went out
2007 SATURN AURA
148,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
KEITH OFFNER
MEMBER
1 POST
Replaced pads, all four tires, bled system. everything good to go two months later the right front brake wheel speed sensor went out
Oct 5, 2019 at 3:59 AM
Experienced Mechanic
Here are a few guides that will help with this:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Below you will find the process from the manual that will help with this as well. Please let us know what questions you have. Thanks
Images (Click to enlarge)
Apr 9, 2021 at 7:59 AM
Add image or video
Ask a new question
Engine Cooling — Leak
Engine won't start
