I'm not able to do that. I'm not trusting Brake Masters answer because I can't afford to replace entire or rebuilt ABS as msgr is suggesting. Or he said bring title to him so he can dispose of truck.
Sep 24, 2020 at 4:41 AM
POIPOIPOUNDER
MEMBER
Thank you for quick reply. I'm doing some research. He says brake fluid is contaminated but the test he showed me, anyone could do as a ruse.
✓Experienced Mechanic
Sounds like he wants the truck.
I would replace the master cylinder and bleed the lines of all air.
Is the gasket under the master cylinder swelled up?
POIPOIPOUNDER
MEMBER
A bit.
Good chance there is a petroleum product in the fluid. It has failed the seals in the master and possibly the calipers and the wheel cylinders.
POIPOIPOUNDER
MEMBER
Thanks Roy! I went to a reliable salvage guy yesterday and he has several ABS for $100.00 vs $450.00 for rebuilt acquired by brake masters. He also has a good mechanic.
Thank you so much for your continued assistance and 'reassurance'. Have a blessed day!
