brakes go all the way to the floor
1,500 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
SANDRA WARDLOW
First ABS light comes on and goes off and comes back on. After a week of driving it like this, the brakes go all the way to the floor, but after pumping they start to work again. Brake fluid full!
Jul 28, 2017 at 4:15 AM
  • 55,684 POSTS
It sounds like you may have two problems, first is the brake master cylinder is bypassing causing the pedal to drop to the floor, here are some guides that will help you with that.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
After you have replaced the master if the light has not gone out I would check the wheel speed sensors here is a guide to show you how that is done.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
and if you find a bad one here is a guide to show you what you are in for when replacing the sensor.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Apr 5, 2021 at 5:03 AM
