Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
1500
Brakes
ABS
Wiring
Brake control
1996 CHEVROLET 1500
150,000 MILES • V8 • 4WD • AUTOMATIC
DAMILT
MEMBER
1 POST
Where can I connect the red wire from the trailer brake control?
Jun 18, 2018 at 12:39 PM
Experienced Mechanic
Good morning.
The red wire should go directly to the battery. Do not tap into any circuit as you will overload that circuit.
Run it through the firewall and to the battery. Use an inline fuse and check in your instructions for the rating required for the installation.
Jun 19, 2018 at 12:56 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Transmission — Not Shifting
