Brake caliper removal
2008 KIA SEDONA
123,000 MILES
RICHARD PACK
How do you get the brake line off the rear caliper?
Feb 14, 2020 at 8:15 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
The hose should have a "banjo bolt" that secures it to the caliper. Each side of the hose will have a copper crush washer that goes on the bolt. I'll post more info below.
The bolt is B and washers are C in the picture below. The bolt should be torqued to 20lb ft.
Feb 14, 2020 at 8:45 AM
JOETECHPRO
  • 705 POSTS
Hey RICHARD PACK,
There will be a banjo bolt securing the rear brake hose to the rear caliper.
You will simply need to undo the banjo bolt and remove the hose.
A picture below shows the rear caliper and hose.
I have also attached diagrams with the tightening torques for the hose and caliper bolts.
Hope this helps, let us know if you have any further questions.
Regards,Joe
Feb 14, 2020 at 8:55 AM
