Sounds like the car is out of tune or missing and brakes not working right?
125,000 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
JIM5763
Bought new hoses and booster. after installation running worse, could it be the wrong booster? Or I installed the hoses on incorrectly?
Sep 6, 2022 at 9:22 PM
  • 55,694 POSTS
Please remove the check valve from the booster (engine off) you should hear vacuum escape. If not, the booster is bad and allows a vacuum leak. Let me know what you find.
Sep 7, 2022 at 2:56 AM
  • 55,694 POSTS
Also, it could be you have a clogged exhaust system, here is a guide to help check it out:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please go over this guide and get back to us.
Jan 3, 2024 at 8:39 AM
