Bought new hoses and booster. after installation running worse, could it be the wrong booster? Or I installed the hoses on incorrectly?
Sep 6, 2022 at 9:22 PM
✓Experienced Mechanic
Please remove the check valve from the booster (engine off) you should hear vacuum escape. If not, the booster is bad and allows a vacuum leak. Let me know what you find.
Sep 7, 2022 at 2:56 AM
Also, it could be you have a clogged exhaust system, here is a guide to help check it out:
