Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Caprice
Brakes
Symptoms
Pedal Hard
brake booster makes pedal hard to push
1992 CHEVROLET CAPRICE
147,000 MILES • 5.7L • 6 CYL • 2WD • AUTOMATIC
LEE WINSLOW
MEMBER
hard brake pedal hard and reduced braking.
Feb 11, 2018 at 5:54 AM
Experienced Mechanic
Good evening.
Check the vacuum line to the power brake booster. it should have vacuum when the engine is running. if it does, the booster has failed and needs to be replaced. if it does not have a vacuum, check the hose as it may be broken or loose.
Feb 11, 2018 at 9:19 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
