Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
MKX
Brakes
Booster
Replace/Remove
Brake booster and master cylinder
2007 LINCOLN MKX
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
HUGGIEBEAR312
MEMBER
The brake booster is bad do I need to replace the master cylinder as well?
Jan 22, 2018 at 1:26 AM
SATURNTECH9
Experienced Mechanic
If the master cylinder is not leaking then no you do not have to.
Jan 22, 2018 at 12:04 PM
HUGGIEBEAR312
MEMBER
Thanks so much
Jan 23, 2018 at 11:38 PM
Add image or video
Ask a new question
Heater — Not Working
Cooling — Not Working
