Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Mustang
Brakes
Booster
Replace/Remove
brake booster cause pedal to go to floor
2009 FORD MUSTANG
76,000 MILES • 4.6L • V8 • 2WD
09GTPONY
MEMBER
can loss of vacuum to brake booster cause pedal to go to floor and loss of braking power?
Mar 12, 2018 at 6:12 AM
Experienced Mechanic
It will cause these issues so I would recommend replacing it. Here is a guide that will help with this:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Below you will find the process from the manual on how to replace this. Please run through this material and let us know if there are questions. Thanks
Images (Click to enlarge)
Mar 5, 2021 at 9:54 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
