ABS valve(a) apparently get stuck open and cause a spongy pedal and problems braking
80,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ANDYEHELER
  • 40 POSTS
Hello again,
I've had an issue as so many have had with the ABS Module on the car listed above SE. The ABS valve(a) apparently get stuck open and cause a spongy pedal and problems braking. There is a recall for the same problem on Fusions and other models which use the same ABS Module, but Focus did not get the recall.
Anyway, I replaced the ABS Module and bled the brakes, the pedal was still very spongy. I re bled the brakes, still spongy. I got a scan tool and performed an ABS Service Bleed to each wheel about 10 times, still spongy. There was a lot of air in the system, but I can't seem to see any more bubbles coming out (unless they're very tiny bubbles, I'm not really sure - see video linked below.) I'm out of brake fluid now, so I'm going to go to the store and buy more. I am fairly certain the master cylinder did not run dry, but I will bleed it if I have to, but would like assistance in that.
Is there a way to easily diagnose where the air would be trapped by isolating the issue to a wheel, etc? I also would like some assistance in that if possible. Thanks.
https://youtu.be/TWMzwyARBtA
Jun 25, 2020 at 2:12 AM
Looks like you pumped the brakes a number of times when you had the bleeder open as there were a few bursts of brake fluid. Did you open the bleeder and then push the pedal down and then let it up and push it down a couple more times and then go close the bleeder? If so, this could be your issue.
You need to have all bleeders closed and pump the pedal. Then hold the pedal down, and open the bleeder, then the pedal will drop to the floor and you hold it at the floor while you close the bleeder. Then you can let the pedal up.
Here is a video that shows this. If you were pumping the pedal with the bleeder open, most likely you are allowing air back in.
https://youtu.be/w7gUsj2us0U
Clearly your video did not show everything that was happening so if that did not happen then you most likely have a master cylinder issue or possible a brake line issue. Here is a guide that runs through this issue:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
What I would do is cap off the master cylinder lines and press the pedal. If the lines are all capped off and the pedal is still spongy then the master cylinder has a leak. If not then you have an issue somewhere in the rest of the system. This is the easiest way to start cutting the system down. if the master cylinder is okay, then add the lines back in one at a times until the pedal gets spongy and then you know which leg it is.
Let me know if you have questions. Thanks
Jun 25, 2020 at 11:35 AM
ANDYEHELER
  • 40 POSTS
To answer your question about pumping the brakes, I had the other end of the hose in a bottle with the hose submerged in brake fluid, so it would be sucking new fluid in. I didn't have a helper to pump and hold at the time. I'll look into trying to cap the master cylinder, I'll look for a video tutorial online. Thanks again.
Jun 25, 2020 at 11:59 PM
Sure. Here is a video. Fast forward if you want to the 5:30 mark. All you need to do is get some bolts that are the same size and depth of the line nut so that it doesn't damage the master cylinder.
The rest of the video is pretty good if you want to watch that as well.
https://youtu.be/YStj8ORkNqY
Jun 26, 2020 at 1:31 PM
ANDYEHELER
  • 40 POSTS
Thanks again. Can you please help me find the correct brake bleeder screws for this 2010 Focus? All the screws that say they fit, according to AutoZone, O'Reilly, Advance Auto, etc. websites don't thread into the caliper. The threads on the new screws look too coarse. Ford Parts website comes up with 0 results when I filter for bleeder. Thanks.
Jun 29, 2020 at 11:22 AM
Unfortunately we are at the mercy of most of these stores. Here is a common parts site that offers these parts:
https://www.rockauto.com/en/catalog/ford,2010,focus,2.0l+l4,1444693,brake+&+wheel+hub,brake+bleeder,1676
The only other possible solution would be to get a used caliper with the bleeder screws or replace the entire caliper. Clearly not a desirable solution but if they just don't fit, I suspect someone changed them.
Jun 30, 2020 at 10:50 AM
