Brake bleeding and the brakes are almost gone
2006 DODGE CARAVAN
270,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
DAVE KOLLMANN
About a week ago the brake cap sealer got a hole in it and the brakes started to lessen with the brake pedal almost bottom ing out on me. I put a condom in the cap for a temporary fix. Now I have no brakes. There is a lot of weight in the van as well though.
Oct 18, 2019 at 8:21 AM
  • 110,241 POSTS
Welcome to 2CarPros.
Does the brake pedal go to the floor? Take a look through this link and let me know if it mirrors what is happening.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
If it is going to the floor, there are no leaks, the fluid is full, and the rubber brake hoses at the calipers are good, suspect a bad master cylinder. Here is a link that explains how in general one is replaced:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
If you could, let me know exactly what is happening at this point as well as what symptoms prompted you to bleed the brakes.
I will watch for your reply.
Feb 21, 2021 at 3:06 AM
