Where can I purchase a brake backing plate?
2006 DODGE CHARGER
12,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
STARLORD1976
  • 173 POSTS
I have the car listed above Daytona top banana R/T. I need a brake backing plate. And people keep sending me the wrong one that doesn’t fit. Can you help me find the right one online to buy. And a picture of it. Thanks
Jun 29, 2021 at 3:35 AM
  • 110,244 POSTS
I assume you are referring to the rear backing plates. I looked up the OEM part numbers and here they are.
Right Rear
5137620AA
Left Rear
5137619AA
I looked up the numbers online and found the original equipment parts to be right around 35.00 dollars each. Here is a link to a dealer that I randomly picked:
https://www.makeitmoparparts.com/2006-chrysler-300-base-gas_2.7_6-transmission_automatic_4-brakes-rear_brakes-backing_plate_5137620AA-item/
Note, the two-part numbers are different, so that means the parts are. Make sure to get the correct one if both aren't needed.
Now, if this is an SRT8, they are different. I will need to know that. I went with the hemi Charger 5.7L since that is what you identified. The SRT8 is a 6.1L
The pic below shows the front backing plates' part numbers.
Pics 2 and 3 are pics of the backing plate. Pic 2 is the rear and pic 3 is the front. Both are for the right side. The left side will be similar.
Jun 29, 2021 at 3:14 PM
