Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
C/K 1500
Exterior Light
Turn Signal
Not Working
Brake and turn signal lights not working
1982 CHEVROLET C/K 1500
200,000 MILES
HANDYHARRY2
MEMBER
1 POST
Right rear turn signal and brake light not working. Replaced bulbs and light receptacle. Still does not work.
Oct 16, 2018 at 4:44 AM
Experienced Mechanic
It sounds like you have a bad ground wire. Here is a guide that will help you test the grounds and power to the brake light bulb:
https://www.2carpros.com/articles/brake-lights-not-working
Here is the wiring diagrams so you can see how the system works.
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Image (Click to enlarge)
Oct 18, 2018 at 3:15 AM
Add image or video
Ask a new question
Engine won't start
Transmission — Not Shifting
