I have changed my master cylinder brake pedal goes to the floor
140,000 MILES • 2.4L • V6 • 2WD • AUTOMATIC
SHELBEE95
I have changed my master cylinder and have bleed. The brakes multiple times. There is no leaks. Brakes are still going to the floor. Help.
Nov 19, 2018 at 8:29 AM
JONNYB1963
  • 263 POSTS
Good morning,
If you are absolutely positive that there are no leaks and you still have a pedal that goes to the floor, I would still be looking at the master cylinder. A couple of questions for you.
1. Does this vehicle have ABS brakes?
2. Is the master cylinder that you installed a brand-new part or a rebuilt?
3. When the pedal does go to the floor, does it go rapidly with little or no resistance? or does it just creep slowly and eventually get to the floor?
Jon
Mar 5, 2021 at 2:50 AM
SHELBEE95
My deacon is a diesel mechanic and he has been the one doing the work. He says no leaks and I brought it to Chabills for them to look at. They said no leaks.
1) Yes.
2) Brand new.
3) Rapidly, little resistance.
  • 55,456 POSTS
This can be caused by a seized caliper slide. Also, did you bench bleed the master before installing it? If not here is a guide to help explain how:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
This guide can help as well:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Cheers, Ken
SHELBEE95
Yes, both master cylinders were bench bled properly.
  • 55,456 POSTS
This car has ABS yes? You will need to have a shop open the the ABS valves one at a time as they bleed the brakes. Air can be trapped inside the ABS unit. One thing you can try is use 4 vise grips and gently close off the brake flex lines to see if the pedal still goes to the floor. If it stays firm the problem is at the wheels if not the master/ABS is to blame. Please let know.
