Brake adjustment
55,083 MILES • 3.6L • V6 • 2WD • AUTOMATIC
KGETZ
  • 104 POSTS
On my van listed above do the rear brakes self-adjust by driving forward and reverse or applying the emergency brake?
Feb 3, 2018 at 11:13 AM
CJ MEDEVAC
  • 11,000 POSTS
They take up the slack gap every time you use the brakes! I believe you can consider that self adjusting.
That is the beauty of disk brakes, less mechanical parts, maintenance is minimal.
They have a guide in there for this too.
https://youtu.be/hPzxdnLJbhc
Let us know how it is going.
The Medic
Feb 20, 2021 at 4:48 AM
KGETZ
  • 104 POSTS
Thanks, the Medic! You answered my question! The rotors and brakes are still like new.
CJ MEDEVAC
  • 11,000 POSTS
The trick is keeping them that way!
Riding the brakes/off and on them constantly instead of coasting down to a stop. The cooler they can be, the longer they will last.
The Medic
KGETZ
  • 104 POSTS
Now the video says about a reset tool if the emergency brake is attached to the back brakes. Can a DIYer do that?
CJ MEDEVAC
  • 11,000 POSTS
Yes, about everything is DIY.
The only thing "brake", that is not normally DIY on these modern computer cars would be bleeding the brake system. Some of these require a meter to open up the system so the brakes will bleed. Most little guys will not spend the money for the tool but will take it to a shop.
Thank goodness for forty and seventy one year old Jeeps!
The Medic
