tire skids when braking
62,514 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
ADEBAYO MOSES
front right wheel tire skids while braking.
Oct 13, 2016 at 5:31 PM
HMAC300
  • 48,601 POSTS
scan for an aABS code and check for a bad hose leading to caliper. it may be grease on lining as well or the other side may be frozen.
Oct 14, 2016 at 12:20 AM
ADEBAYO MOSES
when I scanned the ABS it gave me DTC code number C1314 short circuit in main relay 2 C1353 increase pressure FL solenoid, C1345 linear solenoid valve offset learning undone at which I changed all the ABS relay 1&2 and try to calibrate the car yet still giving the same code and still skidding and all ABS VSC BRAKE light are still ON. " please somebody help!!". Adebayo Moses
Oct 16, 2016 at 7:23 AM
HMAC300
  • 48,601 POSTS
you';ll have to take a mechanic as I thin the abs if messed up and may need rebuilding the abs unit.
Oct 16, 2016 at 8:40 AM
