Brake pedal pulsate and pulls to the left
2001 FORD EXPLORER SPORT TRAC
240,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
  • 8 POSTS
I hear a loud tog, tog, sound when I step on the pedal. When I'm driving on a smooth surface it goes away. All rotors, pads, calipers and hoses are new and bled the whole system.
Aug 19, 2019 at 4:46 AM
BMDOUBLE
  • 1,139 POSTS
Was this sound or pull while braking issue there before the parts were replaced? And were the bearing replaced? I'll give you this guide to help but I'd like to help you if you have any questions at all! https://www.2carpros.com/articles/car-pulls-right-or-left-when-driving-or-braking
Aug 19, 2019 at 4:58 AM
  • 8 POSTS
I didn’t have this problem before I replaced all the parts. When I turn the steering wheel the driver side tire wobbles.
Aug 19, 2019 at 9:14 AM
BMDOUBLE
  • 1,139 POSTS
If this were my vehicle I would remove the wheel on that side and re-inspect everything that had a torque spec. Also make sure the wheel hub nut is not excessively loose.
Aug 20, 2019 at 12:05 AM
  • 55,433 POSTS
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Aug 20, 2019 at 2:46 AM
