Left front brake locking up
2001 CHEVROLET SILVERADO
162,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
BECKE MILLER
Replaced pads and caliper. Checked master cylinder and the piston has returned against the retainer ring. no brake fluid leak seen between the master cylinder and bake booster. Pulled ABS fuse no change. Any idea what next?
Mar 9, 2018 at 12:55 PM
Good afternoon.
The most likely cause is the brake hose. it is collapsed internally not allowing the fluid to return from the caliper.
to verify, apply the brake then release. open the bleeder valve at the caliper. if there is pressure that comes out, the hose is bad.
Feb 22, 2021 at 11:54 AM
BECKE MILLER
Yes thank you was very helpful. Replaced hose is working now. ABS and brake light still on but have not serviced back brakes yet.
Good job. Let us know if you need anything else.
