Will not start after the engine has warmed up?
177,000 MILES • 4.9L • 6 CYL • 2WD • AUTOMATIC
PAUL FERGUSON
When I'm able to start my van it will run and drive when it's cold, but once it gets to normal running temperature it just shuts off and won't start back up, until fully cold. I've replaced the ignition control module, thermostat and housing and the temperature sensor that's in the housing and the coil. I haven't been able to start the van yet because I believe the battery is low (reading about 8 amps or so when trying to start) so I need to charge it. I'm not a mechanic by all means and this van is starting to irritate me bad, and I need my van running and driving, hope you can help. Thanks
Jul 23, 2023 at 11:12 AM
  • 55,732 POSTS
Yes, the battery sounds like it is low on charge or bad. Let's run the codes to see what comes up.
This guide may help as well:
https://www.2carpros.com/articles/comprehensive-guide-reasons-why-a-car-engine-wont-run-when-hot-and
I have seen the ignition switch cause this problem BTW. Check out the images (below). Please let us know what you find.
Jul 24, 2023 at 6:36 AM
