Bought used car that was pretty dirty
160,000 MILES • 2.2L • 4 CYL • AWD • AUTOMATIC
FRO125
I was vacuuming the Outback out and noticed alot of trash under the back seat. I pulled the seat and cleaned the mess. However the felt is nasty and I'd rather replace it. Can I get the right stuff at Home Depot? Thanks.
Sep 15, 2014 at 8:27 AM
  • 110,251 POSTS
I doubt it. Have you called a dealer to see if it is something that can be ordered? I assume you are referring to the felt on the floor under the seat, correct?
Sep 15, 2014 at 11:39 AM
FRO125
Yes- the felt under the back seat bench needs replacing.
Sep 15, 2014 at 12:54 PM
  • 110,251 POSTS
It will either be a dealer part or one from a salvage yard. I guess you could get something at Home Depot and cut it to fit.
Sep 16, 2014 at 1:45 AM
MIKE H R
  • 3,094 POSTS
you can use a winter insulation . They have a couple of different thicknesses . Or you can check on line for replacement floor rugs
Aug 17, 2015 at 11:30 AM
